China 8-60mL EPA Storage Vials
Product Description
1.ND24 EPA Screw Neck Vials(Clear/Amber).
2.Available with black or white screw caps with 24mm thread.
3.Available as closed top screw seals or with centre hole.
4.Nature PTFE/nature Silicone septa 22*3mm
5.Environmental analysis
Features
1) Caps and vials are ideal for sampling and storage.
2) Caps are lined with PTFE/silicone for excellent sealability and chemical resistance.
3) Caps are manufactured of high quality materials to eliminate sample contamination.
4) Environmental analysis Vial.
5) TOC analysis Vial.
6) Pre-cleaning are not available , vials could be used in TOC analysis after cleaning.
7) Purge and Trap Vial.
1.24-400 EPA Screw Neck Vials ND24
Part No.V2017
V2015V3017
V3015V4017
V4015V6017
V6015
Description20mL
Clear EPA
Screw Neck Vial,
27.5*57mm30mL
Clear EPA
Screw Neck Vial,
27.5*75mm40mL
Clear EPA
Screw Neck Vial,
27.5*95mm
Use for TOC&Purge
and Trap System60mL
Clear EPA
Screw Neck Vial,
27.5*140mm
Part No.
V2027
V2025V3027
V3025V4027
V4025V6027
V6025
Description
20mL
Amber EPA
Screw Neck Vial,
27.5*57mm
30mL
Amber EPA
Screw Neck Vial,
27.5*75mm
40mL
Amber EPA
Screw Neck Vial,
27.5*95mm
Use for TOC&Purge
and Trap System60mL
Amber EPA
Screw Neck Vial,
27.5*140mm
Part No.V2017GV3017GV4017G
Description20mL
Clear EPA
Screw Neck Vial,
w/Write-on Spot,
27.5*57mm30mL
Clear EPA
Screw Neck Vial,
w/Write-on Spot,
27.5*75mm40mL
Clear EPA
Screw Neck Vial,
w/Write-on Spot,
27.5*95mm
Use for TOC&Purge
and Trap System
Part No.
V2027GV3027GV4027G
Description
20mL
Amber EPA
Screw Neck Vial,
w/Write-on Spot,
27.5*57mm
30mL
Amber EPA
Screw Neck Vial,
w/Write-on Spot,
27.5*75mm
40mL
Amber EPA
Screw Neck Vial,
w/Write-on Spot,
27.5*95mm
Use for TOC&Purge
and Trap System
2. 24-400 Screw Neck PP Caps and Septa
Part No.SC221221SC221222SC221223SC221224
DescriptionNature PTFE/Nature
Silicone Septa
22*3mm,
24mm White Screw
Polypropylene Cap,
15mm Centre HoleNature PTFE/Nature
Silicone Septa
22*3mm,
24mm White Screw
Polypropylene Cap,
Closed-topNature PTFE/Nature
Silicone Septa
22*3mm,
24mm Black Screw
Polypropylene Cap,
Silicone Septa
22*3mm,
24mm Black Screw
Polypropylene Cap,
Closed-top
Part No.SC228221B-SC228221TOCS228
Description24-400 PP Screw Cap White, Centre Hole, Beige PTFE/Nature Silicone, Low bleeding24-400 PP Screw Cap White, Centre Hole, Beige PTFE/White
Silicone, Low bleeding, Bonded Screw CapsPE Dust Cover, used for 24-400 CapsBeige PTFE/Nature Silicone Septa 22*3mm, Low bleeding
PRODUCT SHOW:China 8-60mL EPA Storage Vials
website:http://www.aijireninc.com/8-60ml-epa-storage-vials/
