China Air Floatation manufacturers
If you are willing to buy high quality pressure dissolved air flotation machine equipment for sludge treatment manufacturers and suppliers in China. WOMA Environmental Protection Equipment is always at your service. Welcome to import dissolved air flotation equipment from our factory. we also offer you the customized service.
Specifications
Model NO.: FZA Type Pressure Dissolved Air flotation Equipment
Flotation Machine Type: Dissolved Air Flotation Machine
Centrifuge Technology Use: Filter
Certificates: ISO
Color: Silver Grey/Blue/Green/etc
Trademark: WOMA
Specification: ISO standard/ international Standard
Method: Combined Treatment
Usage: Industrial, Home, Agriculture, Hospital
Centrifuge Installation: Horizontal
Material: Carbon Steel/Ss304/Ss316
Treating Capacity: 1~300m3/H
Transport Package: Plywood or Wooden Case
Trademark: WOMA
Origin: Wuxi, China
Product description
High Quality Pressure Dissolved Air Flotation Machine Equipment For Sludge Treatment
Model representation
Pressure dissolved air flotation equipment working principle and composition
The use of jet suction principle, the working pressure of about 0.4Mpa, through the high-speed movement of water, so that the air in the shortest possible time, the maximum into the water, and stir into micro-bubbles, the formation of saturated dissolved water. The device consists of dissolved gas tank, return water pump, air compressor, rack and so on, control cabinet set separately.
Pressure dissolved air flotation equipment technical parameters
ModelDissolved water(m3/h)Main motor(kw)Aerated motor(kw)equipment weight(kg)Working weight(kg)
FZA-60207.51.59001000
FZA-8030151.510001500
FZA-10035151.513001900
FZA-15050151.515002400
FZA-20065-70223.019003100
FZA-25080-90223.025004000
FZA-30090-110303.030004900
FZA-500160-170455.542006000
FZA-800260-270907.5650011000
Pressure dissolved air flotation equipment features
1. Simple structure, small size, power consumption, high efficiency, the effect is stable
2. Electrical control safe and reliable, high level of automation. Easy operation and operation.
3. The volume is only one-fifth of the general dissolved gas system, the price is low.
Pressure dissolved air flotation equipment application areas
(1) Remove oil and TSS.
(2) Separate small particles and algae in groundwater.
(3) Recover valuable products in industrial sewage such as paper pulp.
(4) Act as secondary sedimentation tank to separate and concentrate suspended particles and sludge.
We look forward to cooperating with partners from all the world to build win-win cooperation relationship in long term. If you are interested in our products,please contact us!
WOMA(wuxi) environmental protection equipment Co.,Ltd.
Address:Xishan district Wuxi City Jiangsu Province Tin Beizhen Union Village Industrial Park
Contact:FengQihui
Tel:+86-510-8378-0898
Fax:+86-510-8378-0898
Phone:+86-18806179670
Email: 616165253@qq.com
Website: http://www.air-floatation.comChina Air Floatation manufacturers
website:http://www.air-floatation.com/air-floatation/
