2021. 01. 21., 12:08
For the setup of the canon pixma MG2522 printer from the manufacturer, first, you need to make sure that your printer is sealed well.
Now, once you confirm the box is sealed properly, after that you need to begin with the unboxing of the printer & check if all the whole important components are there in the container.
The next step for the canon pixma mg2522 setup is to remove the packing cover from the printer.
Now you need to take out the printer carefully from the container and region it on a flat surface.
The next is that now you need to peel off the protective tapes from the printer.
The next step is to connect the electrical wire to the desired port or the wall outlet for the power supply.
After that, energy-on the printer via urgent its electricity button forcefully.
Now you need to unpack the ink cartridges enclosed with the printer package deal.
The next is to insert the cartridges into the respective slots for the next steps of the setup.
Load confined stack of papers into the enter tray for the process of the canon pixma mg2522 setup
