2021. 01. 27., 13:38
To begin with the process you need to make sure that the canon pixma MG2522 printer is sealed well with the manufacturer’s seal,
Now, after you confirm that if it is sealed properly, the subsequent step would be to unbox the printer & test if the complete vital components are there in the container.
Now, take away the packing cowl from the printer for the process of canon mg2522 printer setup.
Take out the printer cautiously from the box and vicinity it on a flat floor.
The next is you need to peel off the protective tapes from the printer.
Now you need to connect the energy cord to the desired port or the wall outlet for the Canon PIXMA MG2522 setup printer & electricity supply.
After that, power-at the printer by way of urgent its power button forcefully for the process of canon mg2522 printer setup.
The next step is you need to unpack the ink cartridges enclosed with the printer bundle.
Now you need to open the front door of the printer and insert the cartridges into the respective slots.
The last step is you need to load the papers into the input tray and then you need to run the print test if all is good then you have successfully completed the setup.
