China metal carving cnc router factory
Applicable material
Woodworking, Custom Millwork, Fixtures, Channel Letters, Sign Making, Educational, Model Making, Prototyping, Solid Surface Production, Aerospace, Foam Packaging, Plastic Packaging Equipment Manufacturers, PCB Fabricators, Engraving, Metal, Conveyor Manufacturers, Artistic Carvings, Name Tags, Puzzles etc.
Features
1) cast iron machine body with good rigidity
2) Broken-point memory ensures the continuity of work when inciddent happens;
3) Good compatibility: Type3, Artcam .etc.
4) Gantry movement ensures the undeformation after a long-time work as well as a higher accuracy
5) NCSTUDIO/DSP control system and stepper motor.
Specifications
Product namemini cnc router machine
working area300*300mm
machine body structurecast iron
spindle1.5kw
InverterSufar 1.5kw
Guide railHIWIN Linear square guide rail
TransmissionImported Taiwan ballscrew
Driving modestepper motor
spindle coolingwater cooling
Spindle speed0-24000rpm/min
Empty traveling speed0-18000mm/min
Engraving speed15000mm/min
VoltageAC 380V 50/60Hz, three phase
Resetting accuracy0.05mm
Carving InstructionsG code *Uoo *mmg *plt HPGL
Compatible softwareArtcam, Type3, Ucancam, JDpaint, Castmate, such CAD/CAM design software
Control systemDSPor NCstudio
weight150kg
Zhongtang is one of the leading jinan professional mach3 system metal cnc router/metal carving cnc engraver machinery manufacturers and suppliers. From design to engineering and manufacturing, it's all under strict regulatory system. Please rest assured to buy competitive price equipment for sale with us.China metal carving cnc router factory
website:http://www.ztcnclaser.com/metal-cnc-router/
