Fiber Laser Made in China
980/1550nm WDM-Tap Coupler-Isolator Hybrid
Features
l .Wide Operating Wavelength Range
l Low insertion loss
l .High channel isolation
l Ultra Low PDL & PMD
l .High stability and reliability
l .Epoxy Free Optical Path
Applications
l Fiberoptic Amplifier
l .CATA Fiberoptic Links
l WDM Systems
l .Fiberoptic Instruments
l .Transmitters and bFiber Lasers
l Laboratory R & D
Package Dimensions
5.5mm
│← 38mm →│
│← 56mm →│
Performance Specifications
ParameterSingle StageDual Stage
Signal Operation Wavelength Range (nm) C band1530~1560
Pump Channel Wavelength Range(nm)960~990
Isolation (dB) (Over signal wavelength range@23℃,all SOP)≧30≧42
Isolation (dB) ( 4 to 2 @ A signal )≧15
Isolation (dB) ( 1 to 2 or 2 to 1 @ A pump )≧30
Insertion Loss ( over wavelength range and 0 to +70℃,all SOP ) (dB)Pump Channel≦0.6
Sianal Channel≦ 1.3≦1.4
Tap Ratio 1%19.0~21
Tap Ratio 2%16.2~18.0
Tap Ratio 5%12.2~14.0
TDL (dB)≦0.25≦0.3
WDL(dB)≦0.5
Return Loss (dB)≧50
Directivity (dB)≧50
PDL (dB)≦0.15≦0.2
PMD ( ps ) ( Low PMD Option )≦0.05≦0.05
Power Hangling(mW)300
Operating Temperaure (℃)-10~+75
Starage Temperature (℃)-40~+85
Dimension(mm)Ɵ5.5 × L38
Fiber Type
Corning HI 1060 fiber at common/pump port
Corning HI 1060 fiber or SMF-28e fiber at common port
Corning SMF-28e fiber at signal
Date are referenced without connector loss;Specifications may change without notice.
Ordering Information
WTIH□□□□□□□□□
WavelengthStage Tap RatioconfigurationPigtail StyleFiber LengthIn/Out Connector
59=1550nm pass
59=980nm reflectS=Single Stage
D=Dual Stage
01=1%
02=2%
05=5%F=Forward pump
B=Backward pump
1=Bare Fiber
2=900um
Loose tube
1=1m
2=2m0=None
1=FC/APC
2=FC/PC
3=SC/APC
4=SC/PC
5=ST
6=LC
Leveraging on wide experience and expertise, SOPO is well-known as one of the largest manufacturers of 980-1550nm-wdm tap-coupler-isolator hybrid fiber optic high power laser amplifier laser cutter and etching systems companies for its high quality and low price products and excellent service. Please be free to buy cheap products made in China from our factory.Fiber Laser Made in China
website:http://www.sopofiber.com/fiber-laser-1
