grid false ceiling System
1. Product name: U-shaped baffle ceiling
2. Color: White, RAL color available
3. Dimension: W25*H70mm, Custom made available
4. Surface finishing: Powder coated
5. Material: Aluminum alloy
6. Thickness: 0.7mm, Custom made available
7. Shape: Rectangle, custom made available
8. Warranty: 8-10 years
Specification
ProductMaterialThicknessSurface CoatingSizeColor
U-shaped Baffle CeilingAluminum Alloy or Galvanized Steel0.7mm, custom made availablePowder CoatedW25xH70, custom made availableRAL 9016 Traffic White, custom made available
Features
1. Beautiful appearance, and various colors for choice;
2. A more cost efficient solution to roof & wall system;
3. Unique system solutions or custom made designs;
4. Outstanding performance with high quality products;
5. Custom made metal walls available to coordinate with ceilings and other interior / exterior finishings;
6. Open through, same row & equal height features make it suitable for ventilator and hydrant layout, not impacting the whole visual effect, uniform color & glossy;
7. A quick and easy solution to a modern space;
8. Suitable for large open areas with durable and clean look;
9. Fireproof, anti - corrosion, thermo stability and good weather resistance;
10. Certificate: ISO9001:2008, ISO14001:2004, CE, GB/T28001-2011, SGS Test, SONCAP etc;
Accessories
U – shaped baffle Ceiling features flat surfaces effect, beautiful & concise lines, class A2 fireproof, nice moisture proof and easy for installation. It won’t produce harmful gas & substance, no harm to people. No fade in washing, no deformation. The ceiling is easy to saw or cut into special shape, and convenient to maintain.
Application
Industrial and civil buildings, special buildings, interior partitions, suspended ceiling, wall, airport, bus station, museum, opera house, exhibition hall, shopping centra, conference hall, bar and etc.
Installation
OUSILONG has a wide range of ceiling surfaces in accordance with different demands - so that the ceiling are not only extraordinary but unique. We apply various colours, patterns, graphics, embossed textures and perforations to your metal ceiling.
website:http://www.ousilongceiling.com/
