2020. 12. 19., 15:00
HP printer’s users commonly face the problem when their printer just refuses to print anything. This problem can arise due to various reasons ranging from connectivity issues to faulty configurations or drivers. If you are facing any such problem, the following troubleshooting guide will help you get rid of your printer won’t print problem.
1. Go for basic troubleshooting
In case your HP printer stops working, the first thing to do id to check the status of the connection between your printer and your computer. Make sure that all your devices are connected properly to one another, and the network or the cable that you use to connect these devices is working.
You can also take a chance at restarting your HP printer. Turn it off for a couple of minutes, unplug the cord and leave it for a few minutes. Now, plug the cord to the printer and power it on. See if your problem is resolved.
2. Update or reinstall the required drivers
More often than not, printers show problem because of faulty drivers. You may be required to update or reinstall these drivers to fix your printing issue. hp printer problems
3. Set your printer to default
When you try to print something, your computer will automatically assign that printing task to the default printer unless you manually choose to do it with some other printer. So, your HP printer won’t be able to print anything if you have neither set it as your default printer nor select it as the printer to print.
If your HP printer is not set as default then follow these steps to make it your default printer:
Press Window key along with the R key, both at the same time. This will open the Run dialog box. Type Control Panel in the dialog box and hit Enter to open the Control Panel.
Select Devices and Printers from the Control Panel.
