123.hp.com/setup 2600
Download HP Smart App or HP Easy Setup or from support. to setup HP Deskjet 2600 printer wireless to any device. You may also connect the USB cable to your computer to use it as a wired connection. Follow the instruction given here to install HP Deskjet 2600 printer software and set up it. 123.hp.com/setup 2600
Before we proceed please ensure that: 123.hp.com/setup 2600
Your computer is connected to the wireless network.
The computer and router are turned on. And also ensure that the computer is also connected to the same wireless WiFi network from which you want to connect the printer.
The printer is also set up, paper loaded into the given input tray and ink cartridges are installed.
The printer is turned on and places near to the computer and within range of the router for the setup.
How to Setup printer
