ij start canon
First Time Canon Pixma TS3320 Printer Setup
Initially, unpack the Canon Pixma TS3320 printer from the printer box to experience the bliss of your printer.
Next, discard all the wrapping materials surrounding the printer.
Eventually, locate the Canon Pixma TS3320 printer on the flattened surface
Now, plug one end of the power cable to the printer and another end to the power socket.
After few minutes turn ON the Canon Pixma TS3320 printer.
Then, pull out the paper tray and place the papers in the paper tray.
Arrange the papers properly to avoid paper jam errors.
Consequently, place the ink cartridges in its slot and press firmly. ij start canon
Finally, ij.start.canon/ts3320 download and install the Canon Pixma TS3320 driver package.
Canon IJ Setup Wi-fi https ij start canon
You can easily setup your canon printer on your iPad, iPhone or any device. Use the WPS connection method to make it more simple and easy. Follow the below guidelines for quick setup:
Initially, turn on your Canon Printer. ij start canon
ij-start-canon
Next, press the Wi-Fi button on your Canon printer. Wait until the alarm light flashes.
Now, turn towards your access point (router) and push the WPS button on the access point within a few minutes.
The connection will be established, once the Wi-Fi light glows steadily.
