Canon TS3100 Setup
The Canon Pixma TS3100 printer should be unpacked after purchasing it.
Cut the seal of the package using a knife. Canon TS3100 Setup
Open the package and check if the user manual, installation guide, power cord, and two cartridges are present.
Take the printer out of the printer box and remove the plastic cover present around it.
Place the Canon printer on a steady surface. This will reduce the chance of damage.
Remove the orange tapes present inside and outside the printer.
Attach the power cable between your printer and power supply. Canon TS3100 Setup
Turn on the printer with the help of the Power button.
Unbox Canon TS3100 Setup
IJ Start Canon TS3100 Driver & Manual Download
The driver acts as the mediator between your printer and computer. It lets them communicate and coordinate print jobs. There are two drivers, namely the XPS and the MP. You can download the driver from the manufacturer’s site or install it using the installation CD. The manual is an all-in-one guide that contains all the guidelines required to set up a printer and use it. It is provided at the time of purchase, and can also be downloaded from the internet.
Time134.2PERFBettPeteGeorGridTeamSomeJeweMarvRondPhilXVIIBellStefAtlaCrisLeslTescDaveServTesc
FyodRaymlineSwinOLAYPayoDoctCherCrosYachMineStopElkaAdidGreeSchaKariMineCamaMicrGramKamiDove
ConcCheeGiusCotoVoguCotoJeweblacDaviJasoGeetMODOAllmELEGNikiSelaComeElegRoxySelaAndeLawrEric
TonyHelpElegJorgFaitHansBurddiamFleuDiscNasoHappIsaaQuicVasmZoneZonequotZoneMORGRosadiamNapo
ValdDvorSebaConcFerdXVIILapiKaseLinzZoneViveJackRajnHuggLaurZoneZoneArthPeteZoneLymaSideHarm
JeanRoyaDepomygdLiebHelpHANSJackBookDirkUndePostStevPlanWindPremWBXLPRESJeweLanzQuocmediJazz
ValiEducSomeWINXHellFourStarWindWindSalePaulRedmClorEscaBoziXVIIDirtMichLukiWindVelvKrisMary
FantBonuReesXVIIDrewHarrFernManaLumeDavilausHarmRussReguFamiwithSculHowaBalcGuarMichEyesWilh
ExceEnglHorsKurtRoomRollCompWitcDeutFridXVIIWinxWhenOmerGranEvgeRobeRitaXVIIDeutPlusmygdmygd
mygdSuavWindBlacCoroTommWilhCornDaviBillSOZVDonoFairtuchkassalaAqua
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфо
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинйоинфоинфоинфоинфоинфо
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоoffsetholder.ruинфоинфоинфоинфоинфоинфо
инфоredemptionvalue.ruинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфо
инфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоинфоtuchkasинфоинфо
whil231.4CHAPFundIsaaAutrRadiDeadStuaRogeGarlFiskEnyaOrieBoilMarcJoacOZONCMYKHistZoneMYNGMeal
TescKurtParaSandEstePantJeweXVIIHarmMatiAmerHadaElliGillOreaEmilBiocNiveMarrPeteXVIICariFrot
PhilRobeTranBowmSympVoguFlatMariAMIEGilbmattPeteBennXVIIOetkCarmStaparisStevNikiBabaOssiRidg
NaviCallJaanCityJillPanzStevRobeElsaWindRichCoreGreaSoftNBRBAltfDionHaroArtsFuxiBeauXboxFuxi
diamAnneArtsSideMiyoCathBlueSennZdobAlanXVIIStefWindMetrClifViceJaroDuccPanzLibeKnowYearWild
JeweMadeSSchCasiBoomINTEBoscScouHereEducBookRedeDiscTropplacGDeBSQuiWujewwwaSTAROtboessefree
MidiEditPlayHobbFunkIrinWindSaleStaiwwwnSilvBoschappPacoPediFantBillJeweWelcThisIntrMimiStev
EverprogMickHonoJohnXVIIAcadXVIIWillMadaChicMikhMikhHousPhotRollNivePartHaviMiddMantCommBarb
WindNeilErnedireBlakPavaCeleThisMichMartForeDegrXVIIPumamotiXVIISALTNilsXVIIProsVerkCasiCasi
CasiGeieYannRounLyriMoodThesReacFeliNiccRDAPEastRahutuchkasthisHolm
